Diode check
1 year 8 months ago - 1 year 8 months ago #1637 by dynamics
Diode check was created by dynamics
How is diode check of generator control unit done? How can I test a diode while it is still in a circuit without removing it completely from the circuit?
Last edit: 1 year 8 months ago by dynamics.
1 year 8 months ago #1638 by OG GarlicSalt
Replied by OG GarlicSalt on topic Diode check
Do you have a diagram, depending on how the circuit is laid out you can still check it. Also I don't know if this is in all cases but bad diodes I have found before have always produced either an open or extremly high resistance.
1 year 8 months ago #1639 by Mark
Replied by Mark on topic Diode check
There is no way I know of to check diodes (or any other components) inside the GCU.
Any component under test must be isolated on at least one side.
Do have an image of what you're concerned with?
1 year 8 months ago #1642 by OG GarlicSalt
Yeah I'm not seeing anyway to test these units without dissasembly of the LRU.
1 year 8 months ago #1643 by Mark
I cannot post a complete page from any Boeing manual.
I've cut an image from your PDF.....
These diodes cannot be checked from the pins on the unit.
Time to create page: 1.126 seconds
